A new trans is worth more than the car.Id use reg ATF to flush.Then refill with the required atf.My brother changed trans fluid in his mini van and used the wrong fluid.I drained it and changed filter and used the right fluid.Its been 4 years and still no problems from it.He drove it for about a week or so with the wrong fluid.Rocky
Chrysler Firepower
