Typically you hang the doors first and align them to the quarters. Then you hang the fenders and align them to the doors. Sometimes you get lucky and the doors work with the fenders as they are already mounted. Then all you have to contend with is getting to the hinge to body bolts.
But sometimes the fenders need a little massaging after the doors have been off.
Good luck!
Master, again and still
