going from 4.86 to 4.56 is only a 6.2 percent drop in gear ratio, so it should see 400 rpm drop. I am betting it will run as good or better. With the 2.74 low you still have a 12.49 starting line ratio, and that is pretty high.
Greg...I find that interesting. If I crossed the line at 6400 instead of 6800,I would still be in my powerband. Might run a hair faster with 4.56 instead of 4.88s..
Need your rear end checked out? Contact Grizzly!!
