Darn it, not the alternator. I swapped them last night and same flickering of dash lights, radio clock, etc.
Don't know why I didn't think of trying this before, but today I turned the key on (not started) and with just the radio on, I turned on a turn signal. The clock on radio flashed with signal bigtime. Does this eliminate anything since the engine wasn't running. Could it be something with the battery? They are a bit of a pain to swap with the Thermoguards, but will gladly try it if it isn't a complete waste of time. Thank you.
