I have always had to adjust the clutch to release with the pedal very high. If you adjust it to release near the floor, the pedal will not return all the way, and you have to kick it the last bit with the back of your toe. This is with a 3 finger B&B plate. If you run a Diaphram clutch like centerforce, you need to remove the overcenter spring under the dash.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
