This engine is a 440 w/ stage VI heads. When I got it, it had the indy block off plate. I had to switch to a 440 source block off because of the heat crossover under the six pack. I had to bend one lip a tiny bit, but it fit fine and I have no leaks or any other issue.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
