Something is not hooked right if you have a proper baffle in the valve cover. I ran some MT valve covers years ago without baffles and it did this. I bolted a good sized baffle in the valve cover with the PVC valve in it and it fixed my problem.
Either that or your motor is junk.
Rings should and will seat within minutes of the motor running. Sorry to hear about the rear main...
