Basically you are wasting the last 600 rpm's of your
power.... you make peak power at 7300 and in MOST
cases you want to cross the line at 10% above peak HP
but you also need to look at the drop back RPM on the
shifts.. so if its falling down past peak torque its
most likely hurting the ET
