Re: 340 bent valve and still have good compression?
[Re: RTDude]
#131959
10/04/08 03:33 PM
10/04/08 03:33 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Maybe a weak/broken valve spring?
Much more likely that this is the problem, than a bent valve.
The heavy part of the spring is likely broken, and only the dampener is remaining. IT's enough to close the valve on a copmp test, but it bounces while running, giving you your issue
