First BB build in decades. A friend contacted me with a finished short block with TRW 2355 flattops .033" in the hole, the ones with 4 shallow valve notches. With .048" Felpro blue head gaskets and 346's (93CC's) it came to a measured 8.57 CR
. He's considering a set of stealths to raise it. My Question is what cam would you guys recommend that would likely have enough VP clearance? I will clay or dial indicator check what I pick. It's going onto a ~3800lb 4 sp belvedere weekend street brawler with 3.91 gears. No drag strip and he's willing to run however much race gas would be required and he wants a healthy lope & probably a hyd but that's not set in stone. Thank you for your time and recommendations. #1 is the VP issue as the short block is already built
