New guy here...
Originally from the Pittsburgh,PA area now living in Akron, OH. Right now my dad and I are in the process of doing a 70 charger, car is being done pro touring style. Its going to be sassy grass green black vinyl top and black wheels (pretty standard stuff). Got most of my suspension done, magnum force tubular uppers, boxed the lowers, firm feel stage 2 steering box, fast ratio pitman arm/idler arm, Hotchkis adjustable strut arms, Hotchkis adjustable steering arm kit, bilstein shocks on all 4 corners and a set of custom Eaton rear leafs under the car. Front brakes are the standard wilwood 4 piston setup, rears will get the same once the rear end is setup for the car. Just put an order in for a 499 stroker from Compuflow out of Medina, OH, after a fall out with Maund Motorworks. The 4-spd trans for the car was done by Brewers performance and also got a Dana 60 with 3.73 gears from Greg Sandford out of Columbus, OH.
Thats the basics of the car for now and here are a couple pictures...
