Really it has more to do with can the throttle return spring overcoming the open six barrels at 6000 rpm or above. We know we let off the throttle and we know it still pulls. So that could indicate the return spring is not quite doing its job properly. So to some degree "Your results may vary" All depends on your spring tension.
