when you clamp the front part of spring, where do you locate the clamps in relation ship to the fornt spring eye let bolt ? thanks
I use to clamp every leaf I could at the front of that leaf to the main leaf I did end up staggering the rear clamps behind the rear end housing, I ended up leaving the drivers side rear clamp in the stock location and moved the pasenger side up so it was back about the second leaf from the bottom of the stack on the 002 and 003 SS springs, that made the car leave level on the front end foot braking instead of the drivers side being all twisted up Make sure your rear shackle angle is good, not pointed straight down or angle rearwards from the rear spring eye when sitting still in nuetral ![](/ubbthreads/images/graemlins/scope.gif)
