Re: Ok,, Rpms vs Procomp Vicotor js,vs indy??
[Re: MoparBilly]
#1316563
10/07/12 03:08 PM
10/07/12 03:08 PM
Posts: 2,177 ill
dennismopar73
ill
Dennis, What are you looking for? Why are you building a 500, was the current shortblock not good enough? The application, intended use, and goals for a combination have as much to do with head selection as flow numbers.
Sorry for the confusion! Well my current set up is a 383 w 440 crank rod rpms (otb) have been flowed @ 292 at 600, , 12.5 c, stx21 w.1.5 rockers, 456 geared 5200 vert (ta),on alcohol, runs currently 6.70 1/8 @ 103.4 mph 1.423 60, (no 1/4 passes as yet) I am down on cubic inchs , and as this combo is a rather old tec build up (1977pistons) Runs great , just want to get into the 9s , I want to build a 500cu motor over winter, but was looking at upgrading heads, . I have been observing some of my friends combos, mainly their choice of heads, , trying to figure what is the better head to go with ,After seeing a couple combos in use, and saw that they had changed heads, from RPM to a Pro comp style Victor jr head , saw that they was not much of any pick up, over the same set of heads I now have, would the Indy heads be any better for a 500cu, ???
Entire Thread
dennismopar73
10/07/12 03:47 PM
MoparBilly
10/07/12 04:09 PM
dennismopar73
10/07/12 07:08 PM
Big Squeeze
10/07/12 05:53 PM
