Yes , they are moved away from the cylinder bores , with the 4.5 bore the o-ring gets real close to the stock dowl .
so is the kb block just thicker in this area? I was told my indy block was good for 2000+ hp
i wouldn't ever attempt 2000+ horsepower on a Indy block.
So what is the safe power level for an aluminum indy block?
