Re: 5,2 Magnum... Plenum and other things to look out for.
[Re: jbc426]
#1306730
09/20/12 09:35 AM
09/20/12 09:35 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
http://dodgeforum.com/forum/2nd-gen-ram/145873-kegger-intake-mod-diy.html
I have long wondered if instead of cutting off some of the length of the stock beer barrel A hole could be added part way down the runner instead.
The air would then decide Which inlet to enter.
Don't laugh about "the air deciding which path to take" Because Ford engineers found that actually happened And they eliminated an internal runner flap valve That had been designed into their original intake manifold design.
The Magnum V8 total runner length which combines manifold runner plus length of the cylinder head intake port up to the backside of the intake valve is said by Long time Chrysler engineer Willem Weertman to be 18 inches, And appears to resonate in the 3400 to 3600 rpm range Which makes sense If you look at the 1992 Magnum 5.2 rpms of max torque and max horsepower.
http://www.amazon.com/Chrysler-Engines-1922-1998-Willem-Weertman/dp/0768016428
I quote the 18 inches by Weertman Because it is hard to know how to measure it yourself ... Do you measure the top, middle or bottom of the quite rectangular runner passage as it makes its arching path?
A Magnum being set up for acceleration Needs resonation in the 4600 to 5000 rpm range With header lengths to match.
The towing duty iron V10 had 25 inhes which allowed resonation at 1700 rpm.
My fuzzy memory is original 5.7 Hemi was 27 inches but I dont know the current 2013 dual path lengths.
Entire Thread
hp383
09/19/12 03:47 AM
goldmember
09/19/12 04:19 AM
70Cuda383
09/19/12 04:25 AM
coronet1966d
09/19/12 06:26 PM
70Cuda383
09/20/12 01:37 PM
coronet1966d
09/20/12 03:40 PM
70Cuda383
09/20/12 10:09 PM
fox
09/21/12 04:23 AM
coronet1966d
09/21/12 12:34 PM
jbc426
09/19/12 07:08 PM
360view
09/20/12 01:35 PM
jbc426
09/20/12 03:01 PM
