hey guys so the problem is that we still have smoke comming out the right tail pipe. we thought we had this fixed after we fixed the intake gasket that got sucked through and fixed a small hole in the intake port from porting, but it still smokes. we do not have any blow by and the 440 was just built 150 miles ago, so i do not think the valve seals are bad. the engine info: 508 rotating assembly with icon pistons and callies 7.100 rods with stage VI heads and a m1 intake. like i said any ideas would be great. we are getting close to the beginning of hair pulling.
oh we just bought a lead down tester, so i'll post those numbers soon
thanks, Matt
How much time do you have running it AFTER the fix...
could still be burning the oil in the pipes
Beat me to it,and mufflers loaded with soot/oil.
My GTX had an intake gasket leak and it was along time till it all dried up.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
