Mopar performance P/N: P4529514
Or measure the distance between the centerline of each mounting stud and go to your local NAPA and look for some that will fit. That is what I did, and found (if I can remember correctly) a shock for a 2wd Ford truck from the 70's that fit. Remember to check full extention and compressed to get the best fit.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
