see what you have for a fast idle charging voltage at the alt batt terminal and at the batt positive post. Check/clean the bulkhead. use a small metal bristle brush to clean the brass male terminals in that half of the bulkhead and a male brass terminal (NAPA 725147) to clean the female brass terminals in that half
