500 HP won't require the Victor heads & by the time you have the required rockers & other special parts they won't seem quite the bargin...I have Eddy RPM's & if the 440 Source heads had been avalible at the time thats what I would have bought as visually they look much closer to stock so the sleeper effect can be pulled off to some extent...
BTW Welcome to Moparts!!!
