Ok, this is the part I cannot remember. It looks like you said this was on the '72 models??? I have an early build '71 (9-70)I purchased from the original owner in late '77. The doors are/were original to the car, but I took these out. Can you describe or show me (photo) how they bolt/mount back in?
that piece i only found in one of the 6 doors i took apart.
i still have more doors to disassemble..
4 of the doors that didn't have it, i know for sure were 71 doors and they were never taken apart before
i even have the plastic barrier in mint shape i took off
under the door panel.
the door that did have it, had a few differances
besides that part,the guard around the lock was different and something else that escapes me at this moment
thats why i thought it was a 72 piece.
anyway it goes on the top of the window guide
the rubber part catches the leading edge of the interior side of the glass
when the window rolls up.
it is sort of a pita to fit in.
the 2 holes is where it goes
the rubber goes towards the front of the door
the part is sandwiched under these 2 bolts
