Bought a "newly" done Dana with new tubes. Its leaking lube out holes for the case - spreader.
Isn`t the press fit of the tube into the housing supposed to be clean and tight enough to seal?
Outside of a poor fit what else could it be???
Time for a REFUND
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
