SSWWWEEEETT!!! that is looking nice!
kool how a A-body 8 3/4 will just bolt right into the trucks.
are you going down low with it? fliping the shackle? how long did the drive shaft wind up being? bed tubbed yet?
I cant tell by pics but hope the shocks have room with the pipes,they get spred out a good ways.
I had to clearance the cross brace for a fat airshock,stock shocks fits ok if pipes are not in the way.
I just drove mine for the first time with all 3 gears,went 150 miles so far,I think you will like it. my face cheeks hurt from the whole way.
Scratch, I'm only doing the axle flip for now and lowering the front the same by trimming the coils a little, the bed is tubbed with S&W steel tubs and honestly, the drive shaft has me a little nervous...when I attached it to the rear end it sure did slide a long way up into the trans... , gotta do some more checking on that. The shocks look like they are going to clear the pipe, however, when I get the new engine in I may remove them anyway, not sure yet, may go with turndowns and bigger pipes.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
