Not sure if any numbers under .100 change anything in power production .
I believe the minimal amount of duration shown in lash changes has less effect than the change in cam timing itself. looser means less duration tighter a bit more but it also changes valve opening points hence the powerband.
home of the
Sox and Martin Hemi Duster
