4 pinions are stronger than 3, 5 are stronger than 4!
Not necessarily true...the weak part of any aluminum planetary is the spline, not the pinion count.
I have a 727 equipped GV behind my 511 stroker. My 727 has the three pinion gear, bolt in sprag and a reverse manual VB. I also run a Dana. I have had no problems with my set up.
