The rear eye of the front spring is in the original perch just like stock... the front of the spring has the shackles added to the original perch. I will see if I can get pics posted...
this does not sound right. it should have a shackle on the rear eye of the front spring.
it should have the front eye on the front spring in a frame perch thats square looking and a solid mount to the frame.
unless it has been reworked in some way.
you only gain 1/2 of the length of a shackle for lift.. 12" shackles 6" lift.
only reason I can think of to swap ends with the shackle would to be rotate the pinion upwards with a lift. that is not needed with a 2" or 3" lift.( I dont recall any 3" lifts only 2" & 4" & 6 skyjacker kits) and then its still ?able.
like said,you cant go by the 3-3.5 inch rear blocks,as all 4x4 have them to get the ride hieght level.
I am very interested in seeing pics.
