People get pretty clean idles with 250+ at .050 cams and others can't get a clean idle with a cam with 20-30 degrees less duration and overlap.
Maybe it's got more to do with the tune up than the camshaft. The time it using total method crowd are usually pretty good at providing a stinky idle most of the time, unless they get lucky.
