No repops, I am assuming you mean the plastic/tin lock strip? You can get a Ferd part that is a little narrower but fits in the channel of the original gaskets. The only other way to fix it is to get a complete set of 68-69 stainless but you will also need the gasket and clips.
JB Rhinehart, Realist
A-Body's RULE!
