Any tricks or ideas on how to put the side door glass in on a 70 Roadrunner?The vent frames are in and the rear vertical channel is sitting loose in the door.Also can the cat whiskers go on after the glass?Looks like the whiskers slide down over the elongated holes,which looks doable with the glass in,but not sure Thanks
