I forgot to mention gas vaporizes real easy when the temps go up and the plumbing becomes very important. Gas can not be under a vacuum, it will turn to vapor and the pump can't pump vapor, that's why the sound changed.
Good info. I wonder if he eases the restriction on the inlet side if that will take care of it
