4200 is a prorated number. The customer is located in Arizona with a lot of heat and thin air factored into the selection also. This as well as all the specs on his combo was gone over in great detail before a selection was made. The 318 has a 3.31 stroke and notoriously low on low end torque, therefore you would want to have the loose enough to get into the torque of the engine as well as having good lockup capabilities. I very confident this customer is well on his way to a substantial improvement all the way around.
Lenny, would a converter set up for this combo work OK with a 3.73 gear and 28 inch tires? Mostly street, need decent lockup at cruise of 60 to 65 mph and able to keep it cool with a big trans cooler.
