Back in the day, we used to shove balls of aluminum foil into the head and then cover with a thin patch of sheet metal. Then we would wire the crossover valve in the manifold open or drill it out, tap the holes and put bolts in. Always worked fine. With todays gas, this is a must to do since the added heat evaporates the fuel.
