I'm assuming it is carbon, but it might not be. What causes the black (carbon?) in intake runners and in a carb?
Ran a 750 Holley vacuum secondary carb maybe 10 to 20 hours last year on my daughter's 67 coronet with a 383. Was freshly rebuilt when I installed it. The carb is now heavy black.
My cousin's 400 cid 67 Firebird with a Paxton supercharger has half the runners black and half clean. Its a dual plane that we now know is a mistake. The cylinders that are rich have the black runners.
What is causing this?
The Pontiac just has the wrong cam in it... any pressurized
engine doesnt like over lap on the cam... as to your
other car what did you put in for a cam and did you
degree it... did you do a valve job on it
