Quote: Mike as others have stated that is a sweet sounding ride.
I do have one ? And I only ask because a friend on mine's car is doin the same thing. In the video when you whacked the throttle in front of the garage. I appears it is smoking out the right tail pipe. What do you think that might be? Jim
Right now I'm not sure if its steam from a header bolt (water getting in) or if its my oil leak... I see oil right at the ball socket(joint) so it might be getting in there... right now I have a few other things that are higher on the list... I also have 1 head that I had to tube the push rod hole because I went to far on porting but I dont think thats the problem.. gotta fix 2 oil fittings then check it
