The stock MOPAR unit has a "shoe" on the bottom of the pickup which maintains clearance between the bottom of the pan and the screen. Its a good design which is easy to install correctly. Aftermarket units don't have the shoe. Precise installation is required to maintain clearance and if the tube moves around in use you could loose clearance. Even if the pan gets crunched a little the stock unit will still work and maintain oil flow.
