That will not be to hard. Thats close to my 493 build and I have hit 10.70's at 3700 lbs with only 7 passes on it so far and I race it as I drive it on 92 pump through the full exh system. I used a 440Source 4.15 kit and dished pistons for pump friendly 10.6 comp. Heads are Indy EZ heads worked by Dwayne Porter and a solid flat tappet cam speced by Dwayne also. I am using the Indy dual plane intake with an 850 DP and a Mallory dist.
I would call Dwayne Porter for your heads and cam. I bought my heads and cam right from him as he worked the heads some and speced out a nice cam for the combo. And his prices are fair and he is a nice guy who is easy to work with. I think I have 10.50's in mine if I ever get to some serious tuning and maybe try a dominator carb. Good luck , Ron
