How has everyone found the fit and alignment of the lakewood bellhousings for big blocks to be? I want to get one for my hemi but have heard many stories of them being out of alignment.
Thats what the offset dowel pins are for... you should
check it anyways for run out
how do you do that ?
Im looking for a 4 speed setup on my ROAD RUNNER
Mount a dial indicator on the back of the crank and
indicate the inside of the hole for the trans...
slowly turn the crank around and see if it has run
out... you want like .003 or less if I remember that
number right
