iv had 4 727 trannys with shift kits. The 1 I installed in my 71 RRwas a kit from Art Carr. I never had a problem with it.
I had the Trans Go kits in 3 727s. I installed 2 of them and 1 was installed by a tranny shop. They all worked fine under street driving. BUT every time I took the cars with the Trans Go kits to the drags I would have to drop the pan the next day. The accumulator vale snap ring would get pushed out causing the piston to put to much pressure on the rear band lever resulting in the tranny to not work right.. I would install a new snap ring and all would be fine till the next time to the drags. Thank god for having a trailer. Kinda humble to need to trailer a low 14 second car to the track..
