Sounds like you experts are getting to the bottom of Mark's Miata AC issue, so I want to jump and ask this- my 2008 Avenger 2.4 has the electrical plug damaged on the front of the compressor. Is there a diagram that shows which plug pin goes to what color wire (2 pins only)? And, since the whole thing is damaged but the 2 pins on the compressor are still there, can I simply solder the wires on directly, then pot the whole area in sealant and call it good until some serious AC work is needed?
Thanks!
