Made the conversion to the factory XHD leafs out back and the Firm Feel front hangers. I installed the springs at the higher front hanger position for the 1" lower option.
Question is would you leave the Factory pinion snubber on the 8 3/4?
Its going to be close....
Or would you cut the rubber snubber off a little for a certain amount of clearance in the at rest position for a Street car not an all out track car.
