My car will run 6.50-6.60 depending on the weather. NO trans brake, NO air/electric shifter, the driver has to do all the work. That has been the problem lately,,,the driver hasn't been doing the job correctly. It has gone alittle quicker, but, it was 45*-50* last Fall at Clay City. I know where this is headed,,,you are planning on being at the race and want a "duck" somewhere in the early rounds. Better get me the first round, cause if you all don't, someone will!!
If I get through the first round, I'm will be HARD to handle later as my confidence will be WAY up..
