As long as the red is still good, the best thing to do is to clear coat it. Glass bead it first so the clear can get a good gite. I've done this to many, many taillite lenses with excellent results.
It also works with many of the new headlights that get so cloudy. Sand them down good with 500 or so till smooth and use the left-over clear from a paint job to bring them back to life.
I can't glass bead it because that will remove the chrome from the trim that's glued to the lens, and there doesn't seem to be any way to remove the chrome trim from the lens without ruining it.
Earning every penny of that moderator paycheck.
DBAP
