Searching for reasons why I've burnt out my 2nd set of low clutches in 3 years.
If the drive shaft bottomed out on the launch when everything winds up, could that be putting pressure on the clutches and frying them? Not sure how much play I have as the tranny is already sitting on the garage floor, but will be putting it back in to check the spine depth.
Any other ideas?
No that wouldn't do it.
