I found this list of parts on another web-site...
It's an accurate list of parts still available from your local Chrysler dealer as of a couple of months ago..........
door lock cylinder gaskets 55074799
fuel level ground strap 2258862
speedo cable 04897646AA
valve stem extenders 02401840
brake backing plugs 2072614
hood pop up spring 2935375
clutch boot 3515300
dimmer switch 1881938
glove box lens 2822583
torsion bar boots 2071173
fuel pump bolt 6023526
seat knob 2583623
rear diff vent 4032798
short battery "J" bolt 2534814
long battery "J" bolt 2074089
throttle cable hold down clamp 2402210
nut for above 6025006
front shock washers 2206925
bottom rear shock washer- inner 1319555
bottom rear shock washer- outer 1319554
steering box bolt 6028193
Hurst 4 speed shifter mechanism 4019122
Chrome LH remote "A" and "B" 68-70 Mirror 3695508
14" trim ring (wheel) 2944424
1990 truck exterior door handles 4217710 and 4217711
70-71 square 4 speed shifter boot 3467770
Dana 60 cover gasket 3634985
gas tank filler grommet 3404182
tank sender seal 1948757
t-stat housing 3698565
upper control arm bumper 4014050
lower control arm bumper 2948716
3/8th fuel sender filter 2534111
26" fan shroud 69-71 2998326
71 "B" body washer bottle 3431074
63-up bellhousing shift fork boot 3515300
8 3/4 Diff nuts 6028915
diff u bolts 3491296
nuts above 6023018
rear leaf spring bushing 1940725
sunvisor tips 2789037
I found it to be quite interesting, thought I would post it here.......
