Re: What gear ratio with blown Hemi, 727, 30 inch tire?
[Re: gregsdart]
#1235447
05/21/12 05:55 PM
05/21/12 05:55 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
With the 3.55 and guessing about 900 ft lbs torque, the 3.55 with a 30 inch tire will have a ton of launch torque. Starting line ratio is 2.45 x 3.55 =8.70. Torque times 2 (converter multiplication) times SLR is 15660 ft lbs at the axle, and less at the tire ,12528. Take away 10 percent for driveline loss, you still have 11275 lbs of thrust. Divide by the car weight, the thrust in Gs comes out to 3.09. I doubt you will be able to dead hook the car with a 3.55 gear. Maybe a 2.76, but Danas don't come with those . So the 3.55 is your best bet for now. Tub it, put a 15 x 33 x 15 slick on it and some wheeliebars and ride the back tires to the 60 foot mark!
Thanks for the calculations,tubbing has crossed my mind after this past weekend. I saw 2) 55 chevies with 20inch wheels 15" wide on the rear and both cars were about 6 inches off of the ground.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
Entire Thread
67HEMI
05/18/12 06:02 PM
Thumperdart
05/18/12 06:35 PM
HEMIFRED
05/18/12 08:27 PM
Blown 68 R/T
05/18/12 09:10 PM
67HEMI
05/21/12 09:50 PM
67HEMI
05/21/12 09:48 PM
Cab_Burge
05/21/12 09:57 PM
gregsdart
05/19/12 12:56 AM
hemi-itis
05/19/12 02:32 PM
67HEMI
05/21/12 09:56 PM
67HEMI
05/21/12 09:55 PM
Clanton
05/21/12 01:35 AM
