ha, everything is very close, just my timing is slightly different and it has 180 psi cranking pressure. Timing is 18 initial and 32 total. Has a MP 284/484 cam installed 4 degrees advanced. stock intake and 452 heads. hooker fenderwell headers, thermoquad built by me to demonsizzlers specs. Been the same for the last 8 years since i built it and only has about 2000 miles on the build..
