Actually it takes about 1800 hp to run up front. I need a 1.15 to 1.18 short time to get where I need to be. The tire is amazing. I've seen a 1.13 sixty at 3200#. I will weigh 3275# with the Procharger. I bet I hit near 2000 hp on the dyno! The Challengers long wheel base is a plus. Going to run a 2 speed turbo 400 by Proformance transmissions and a PTC converter.
I would like to see some progress pics of your challenger sometime
