I'm considering running my 1969 340 Barracuda in PS, probably D/PS. It's an original 340 car and you don't need a rollbar in PS. I don't want to hack up the car, but I'll have to figure out how to install a driveshaft hoop without hacking up the floorpan. I have another 340 on the engine stand with TRW replacement pistons. Just a cam change and I should be good to go there. I'll probably switch over from the 4-speed to a 727. I have a 9" converter that might work pretty well for PS.
Thin shims under the rocker shaft will let the lifters extend so you can run the engine to higher rpm if you want to.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
