If I was doing this I would put a jack stand under the connector where it's hitting the floor and set the cars weight on it. That would form the floor to the shape of the connector. You could take a grinder to the connector and make it fit the floor. It looks like the floor has had some repair work done in that area and may not be the same shape as factory original.
