Bear in mind that if you have a "perfect" 14.7:1 a.f.r. at cruise, you'll probably have a few lean and rich cylinders somewhere. I got to the high 13's at cruise and called it good enough. I have my o2 sensor mounted 12" from the turbine outlet, so I know all the exhaust is thoroughly mixed by then.
If you are running 10% ethanol pump gas your ideal AFR is 14.1 to 1.
